Results 1 to 20 of 20
Thread: static drop my DD
    Martinsville, VA
    static drop my DD
    Looking to drop my truck a couple more inches. I'm thinking monolift in back and heating front coils. Any ides I'm kinda low on money ATM though. I know all bout drop spindles and stuff but trying to keep as much in my pocket as possible.
    Stafford, VA
    Chevy V8
    HEY MAN...glad to see some other members from va. im in stafford with a full bag and body drop backhalf project on my 95 mitsu swb.....my buddy has a 87 d50 longbed reg cab all stock till we bag it this winter.
    Jacksonville, FL
    G54B-T
    Dont heat the coil springs.....just cut a coil or two if u like. Then get some 3-4 inch blocks for the rear and take out the middle leaf. There's a good write up here on cutting coils.
    Stafford, VA
    Chevy V8
    I second what crvtec90 says....heating the coils takes away the strength/temperment. And it make for a worse ride....i know this from experience....just get some shorter shocks and or relocate the ones you got if needed...
    You want to cut 1 coil off. Just use a sawzall. Avoid heat as much as possible.
    Check out the Fear Monger by
    Stafford, VA
    Chevy V8
    i would aim at 2 coils but do as camoit says....cut 1 then slap it all together and see what you think....1 is like very mild. 2'' i believe.
    cut the bump stops in half or you will be on them after you drop it.
    las vegas
    i cut 1 coil and removed the bump stops front and rear and took the biggest arched leaf out and 3'' bolts it rides smooth
    how about a picture.
    las vegas
    Looks like it sits nice and flat. And won't hit the concrete bumpers with the front.
    las vegas
    does anyone have pics of 2 coils cut or the 2.5 lowering springs?
    The last pic of the white truck is just about how a truck would sit with only drop coils in the front
    Josh
    09 BMW 335i E92 Twin turbo
    British Columbia, Canada
    1986 Dodge D-50
    Quote Originally Posted by phatmax View Post
    Part # 4270 Belltech coil spring set, 83-97 Mighty Max, 2.5" front drop
    -RHP
    Try looking in here. tecjones just did the 1.5" cut spring.
    http://www.mightyram50.net/vbulletin...php?albumid=11
    Rockledge, PA
    I just did mine this weekend with new bell tech drop springs and shocks. Pics in my gallary.
    Jacksonville, FL
    G54B-T
    Ive been looking at the monoleaf rear springs but im gonna stick with my drop blocks for now
    Las Vegas NV
    Hey man! hate to bring back a dead thread but ive been searching the forums to see if i can find a solution to my problem and im hoping you can help. I also have the beltec lowering kit for my 92 MM rear is finished but as for the front i am having a hard time finishing the install it seems like the shocks are maybe the incorrect ones but i cant get the top to go in fully and get the lca to bolt back up. Did you have to take out the whole LCA like the ball joint then work from there? any advice would be helpful, thank you!
    mike
    Las Vegas NV
    mike
    ps my bad on the previous post I didn't realize it was black font haha
    Hmm, dead thread and 2 broken links...
