(never mind over looked the cable on RockAuto. Still... I find it hard to believe a steel braided cable can stretch to such a point.. and I want to see if that spring on the cable in the rear drum is actually fully compressed or just looks like it. If it is... I don't see how the cable is the problem.
. Should've added a warning about deleting the charcoal cannister. It is best to leave it in place as the fuel tank vapours can expand and really need somewhere safe to go, plus it prevents the tank from vapour locking (both from vacuum and expansion). The end results can be unpredictable - truck just dies from sudden fuel starvation, blow a hose or filter from over pressurisation or wreck the carb depending on how hot the weather is, venting gas vapours and EXPLODING which could be a bit inconvenient...
