Quote Originally Posted by Ecarmich View Post
update so since i couldn't find a replacement from advance or auto zone i finally found one at a pull apart and got a new one. i put it on this past weekend and it smokes right where the 3 bolts connect to the exhaust. also one of the bolt was burred out. so i tried to run a bolt in to reopen the threads but dont think that worked very well. i put red thread locker on it and put it back together. my question is will this have any effect on me driving it, like will there be any back pressure on the system that would cause the truck not to run right?
don't want to sound like a smart ass but you did put the gasket back when you reinstalled didn't you and if so did you replace with a new one or did you use the old one? that would be the only reason i could see it smoking.
