When I took mine of my 87, it wasn't too hard, there are three bolts on the drivers side, underneath the fender on the frame that hold the box on, and there is two bolts at the bottom of the steering "rod" (IDK what its called, but it is the rod that goes from the steering wheel to the steering box), where it connects to the steering box, and you take those off, then the last one is the one that holds the steering arm on the tie-rod, and its just one nut with a cotter pin in it (Remember to not loose it, like I did). And disconnect the power steering lines. Then you should be able to lift the box out.
