Results 1 to 9 of 9
Thread: Rear leaf spring bushings and shackles
    Hilo, Hawaii
    1989 Dodge Power Ram 50
    I'm in need of replacing my rear leaf spring bushings and shackles for my 89 Ram/50 4x4. does anyone know of an upgrade. The truck is my DD but I also use it for hauling, as well as, some off-roading. I've searched Energy Suspension and Prothane but the only list Moog as replacements. Any suggestions?
    los angeles
    i picked up a bunch of energy suspension bushings for my '94 here. here's what they have for the '89. http://www.energysuspensionparts.com...ighty_max_1989
    sharon mass
    i just did rear shackles and bushing on my 1988 2 wheel drive. i got them from www.mitsubishipartswarehouse.com. factory original parts. type in do not use the link takes you to godaddy for some reason!!!!
    Hilo, Hawaii
    Mahalo steen3rddensity for your response; I e-mailed Energy Suspension to see if the bushings will fit my 4x4, because I'm not sure if the 2wd bushings are compatible with the 4wd model.
    Hilo, Hawaii
    Mahalo (Thank You) for your response, If I can't get an upgraded set for my truck, I will definitely go this route. The Mighty Max "is" pretty much the same truck, right?
    Thank You
    Exact same truck besides grill.
    manchester, tn
    Siberian bushing has a exact replacement. They are out of Russia. Part# 3-06-1797.
    My truck has nolothane all around. Can get them off the shelf here
    Link for bushings - they have all the bushings front and rear and sway- away torsion bars (same as swb 1st gen Montero): http://shop.adventuredrivendesign.co...ory&path=71_72
