To be honest, unless you know which seal is the culprit, I'd change all of them (there are only 3 seals - crank and 2 balance shaft seals). You can bet good money that even if you replace the worn seal, the others aren't far behind (lets face it, you have to take it apart to get to one seal which means half the job is already done)
