Junior
Holly has a new EFI 2 barrel!
https://bangshift.com/bangshiftapex/...wo-barrel-efi/
YUP they got a 2300 flange efi two barrel. I can't wait to try this out. I'm already getting 25.5 MPG and I think this might push me to 27 in the summer when I don't need the choke and I can run lean because of the hot air. Plus it should start and idle like a dream!
Nice Idea, but 1200 for the full kit is as much as the 4 bbl kits for v8s. Does look intriguing though. Time for me to pull out the single bbl Holley projection...
the old projection seemed reasonable ~$600.
$1200 is alot of dough for a 'compromise'. Still wet manifold. A hack
I'm thinking the MPI 2.4 + a piggyback, or prebuit megasquirt, will surpass it for le$$
Not plug n play(or pray) tho, if that's what you're after
A buddy dumped a load on MSD Atomic for his turbo LS..... honestly wasn't all that. Had issues. I avoid their brands personally
