Results 1 to 18 of 18
Thread: 86 Ram 50 Transmission Questions (Automatic)
    Payette, ID
    It is so when you floor it, or just give it alot of throttle, such as pulling a hill, it will force the transmission to use a lower gear, so you are higher in the RPM range and have more power.
    Also, I asked if you had a 2.0 or 2.6, because it is hard to find a header for a 2.0. The easiest way to find out if your engine is a 2.0 or 2.6, it will say on the plate that is on the radiator support (I believe that is where it is on a ram 50), if it says G63B, it is a 2.0, if it says G54B, it is a 2.6, or look at the exaust manifold, a 2.0 looks like this (Mine with a Weber 32/36), and a 2.6 looks like this (also with a Weber).
    Here is a Wikipedia link
    http://en.wikipedia.org/wiki/Automatic_transmission
    Also when looking for a Weber, do not buy a Weber 32/36 DFAV, it is very hard to get parts and instructions for, or a Weber for a standard, get a 32/36, that is for an auto, also make sure "Weber is cast on the carb"
    Harpers Ferry, WV
    Thanks for the help. I understand the kick down now. Does a weber come with the appropriate linkage to reinstall the kickdown cable? Also I am a little confused about your weber recomendation. One line says dont buy a 32/36 dfav, the other line seems to say buy a 32/26.
    I know my exhaust ports are evenly spaced yet not exactly sure if its a 2.0 or a 2.6. Will have to check tomorrow in the daylight. How does one post pictures with a post. I will post some pictures tomorrow and if you can take a look that would be great.
    I am excited about this build and appreciate all the help this forum is providing. The weber I am looking at is on ebay. Heres the link:
    http://www.ebay.com/itm/MITSUBISHI-D...item2313e3c23b
    Its a 32/36 DFEV with E. Choke. I am assuming this will do the trick?
    Seth
    Payette, ID
    Click the image of the tree at the top left of the Quick reply box to post photos.
