Results 1 to 3 of 3
Thread: Electrical ?
    mass.
    1991 Mitsubishi Mighty Max
    Electrical ?
    New battery, and alternator. Still have slow moving wipers, dim lights, and slow reaction from radio. Any suggestions would be a help thanks. Gs.
    Have you gone through all your ground lead connections and cleaned them? Dirty grounds can cause starter motors to struggle, poor battery charging and all kinds of electrical issues. Also check the main ground leads for signs of corrosion. This can create high resistance/load points that affect amp output.
    Also, make sure the battery clamps are in good shape. Geezer has the right approach: the ground leads on these trucks need to be clean.
