The accelerator enrichment pump is the square block on the side of the carb with a fuel line in and out. Top barb is from the fuel pump, bottom barb goes to the return line. The primary and secondary fuel feed lines (from the pump) are different diameters (primary/fuel bowl line is obviously the bigger diameter hose). It wn't kill the carb but the engine won't run right if they're swapped.
