Results 1 to 5 of 5
Thread: 3rd time is a charm where do these hook up
    Kellogg, Idaho
    I have tried to post this question twice but some how the post never shows up. Lets hope I do it right this time.
    I need help identifying where some wires and hoses go.
    1. First one is a vacuum nipple coming off the back of the intake manifold. Plug it or run it to where?
    2. Center hose fitting on canister, leave open or run a vacuum line to ?
    3. IMG_20171210_172023480.jpg The wires shown are cut and the other side of the plug is empty. I have a single cut wire on the harness that is cut and hanging not sure if it goes to this but where do these 2 wires go?
    4. On the passenger fender wall is a single black wire near the plug wire for the air filter canister. it has bee cut and is hanging. where does it go.
    Looks like your engine is the 4G64 (2.4). The black module is a power transistor. Not super helpful - I've had a McGoogle for images etc but that 2 pin connector doesn't come up.
    Kellogg, Idaho
    Well i've figured out some of the issues. Here is what I don't know yet. In the photo you will see a wire hanging behind the 2 cut wires. It is either white with a red stripe or yellow with a red stripe. Now idea where it goes. I think the 2 cut wires are for an EGR temp sensor. Can't find any data to tell me where this would be located. Finally the vacuum nipple on the intake might be for cruse control so I'll just plug it.
    az
    Yes the 2 wires in your pic are the EGR temp sensor. Maybe you will get lucky and find one at a you pull it yard that some one cut the connector off of. Otherwise it is off to the parts store for you... or RockAuto...
