Results 1 to 4 of 4
Thread: Tensioner Confusion
    ID
    4G63
    Tensioner Confusion
    Hi Guys,
    The manual lists torque specs for the:
    Automatic Tensioner Bolt
    and
    Timing Belt Tensioner Bolt
    Which is which?
    I think you are confusing the Tensioner Spacer(which is a bolt) and the Tensioner Bolt (which set the tension on the timing belt)
    page 11-C35 actually check out the entire section.
    http://mmeierle.com/images/Max/1G%20...2%20ENGINE.pdf
    ID
    4G63
    I assumed that one was the spacer and one was the bolt, but the manual doesn't provide a description of either. However, after looking at your doc, I see the spec for each. The spacer is 49ft and so is the bolt. But mine shows the Automatic Tensioner with a different value.
    Automatic Tensioner Bolt 14-20
    Timing Belt Tensioner Bolt 32-40
    So I'm not sure what they are talking about. But yours sounds pretty good to me so that's what I will go with.
    Also, your doc is for a 92, mine's an 88. Hopefully they're the same.
    ID
    4G63
    I just spotted the Auto Tensioner in your diagram.
    I don't have one of those.
