Results 1 to 11 of 11
Thread: Auburn Gear limited slip diff.
    Vanessa, Ontario
    1989 Dodge Power Ram 50
    does anyone know if there are any Auburn gear limited slip differentials available on the web?
    That's a big 10 NO buddy.
    You can put in some of the old Montero LSD that's all.
    Find me on FaceBook
    Powerbrute LSDs are available on ebay - they are new version of the Montero lsd.
    Los Angeles
    1980 Plymouth Arrow Truck
    Here is the one I used. I think it's a Powerbrute that Pennyman suggested. I found it on Ebay.
    http://www.mightyram50.net/vbulletin...op-Wheels-Diff
    Vanessa, Ontario
    I checked them out and the 1988 isn't compatible.
    Owensboro, KY
    4D56-T
    It should work, all MM/D50s have the same rear end.
    that lsd is good for all 8" rear axles in the trucks to 1994 at least
    Delano, Ca
    What about a welded diff ?
    Vanessa, Ontario
    i suppose if I wanted to burn the tires off I could weld it.
    Welded diff...get a funeral plan. Lethal in the wet, horrid doing tight turns, disastrous on gravel, rough on the drivetrain. Probably one of the worst ghetto mods you could do to any vehicle. Worst case scenario use the whole rear out of a Monty. If you think you can get away with it, find one from someone claiming it needs to be rebuilt. Found an interesting thread topic on another forum - http://www.mightyram50.net/vbulletin...ll=1#post58403 (link is in the post) This is a little like my engine flush method.
    Vanessa, Ontario
    I found these also. http://www.autoanything.com/drivetra.../10A56016.aspx Does anyone have any experience with the G2 Limited Slip?
