Junior
Crank Bearing Question (or two)
Hi guys,
Maybe someone can help clarify my bearing situation.
I just got my rebuilt crank. According to the tag it was ground .10. But the bearings they included are .25. Shouldn't the new bearings also be .10? Or am I misunderstanding?
Also, the rod bearings are about 2.5mm narrower than the stock bearings (the mains are the correct width). That can't be right, can it?
Any help would be greatly appreciated.
