Results 1 to 11 of 11
Thread: Timing chain G54b breaking guides
    If they didn't use a balance shaft delete chain, the chain would be too long. They probably tried to take up the slack by using all the adjustment of the guides - that would cause the chain to slap and do the damage you see.
    sandpoint, idaho
    1987 Mitsubishi Pajero
    so i removed the guides and oil pump and tentioner, the tentioner and guides are all grooved badly and the guide that is broken in the picture is actually missing a 1.5"s off the top.. Im going to order a new oil pump just in case any suggestions it has had a melling the last two times..
    sandpoint, idaho
    what does the timing chain have to do with the balance shaft on the oil pump assembly they are separate from each other?
