Results 1 to 5 of 5
Thread: Oil pump key
    Ohio
    1985 Dodge Power Ram 50
    Oil pump key
    Does anyone know what the dimensions of the oil pump woodruff key are? I lost mine and need a new one, or would a homemade one suffice?
    Turtle Island
    Would the oil pump wooddruff key from a 1988 MM be the same size? Also you do mean the steering gear oil pump right?
    Ohio
    No, the oil pump for the g54b is run off the timing chain and has a woodruff key to keep the sprocket aligned
    Can't see why a home made key wouldn't do the job. Plenty of old timer mechanics made their own keys out of stock and ground it down to fit.
    Turtle Island
    Sorry, don't know.
