Results 1 to 6 of 6
Thread: Shifter Parts
    Lynchburg, VA
    Shifter Parts
    Where would i find a new shifter boot (small hidden boot at the base of the shifter that covers ball)
    White plastic bushing that goes over metal ball at end of shifter
    Flange gasket
    Lynchburg, VA
    I would think these wear items would be easy to find but no luck on ebay or Amazon
    Online
    Pukwana, SD
    Might look up the part numbers and type them into a web search and there are import companies that will show a listing and price. Some weird parts may still be available in the US that will come up also but often you order and they say no longer available but it's worth a shot. Check the shifter bushing at rockauto they had them in the past. The gasket a jeep 2.5 throttle body gasket will work with a little trimming Fel-Pro 60747.
    Mike Warme on here has the shifter bushing and maybe the gasket and shifter boot.
    pa
    I can still buy shifter bushes over the counter from the Mitsu parts distributor locally (last one I bought wasn't cheap but I was able to walk in and buy it on the spot)
