aw372 questions
Need to know drain and fill capacity of the oil pan. Also want to remove extension housing to replace bushing. Does the speedodometer cable drive have to be removed from the housing or just the cable removed? A shop manual with diagrams would help. Have searched for days trying to get info on this tranny ! Thanks
Bachelors Degree
If no drain plug on the pan then drop the pan (replace the filter since you have it down.) The one I have on the floor in the shed looks like the converter has no drain plug on it. Fill and check as you go!
Search for aw372 schematic for a breakdown of the trans!
