Results 1 to 5 of 5
Thread: Dohc swap. Wanna confirm
    Iowa
    1991 Dodge D-50
    So im getting ready to start getting the parts for my dohc swap so i just wanted to make a thread with the list i think i needto make sure i got everything correct. So far i got:
    G63t 6 bolt head with intake(modded for rwd), fuel rail, etc
    Sensors, ecu, and harnefrom 1g dsm
    4G64 dohc cam gears
    G63 headgasket
    Then the typical water routing stuff with a full 63 swap. Am i missing anything?0911171908a.jpg
    miami, fl
    1991 Dodge D-50
    ummm.... the wealth of info already posted, especially in the 'sticky' topics
    no idea exactly what flavour dohc u tryin to build either. 63, 64, turbo ?
    Another member has asked about improving the HP from their 4G64 so I added this link as a starter -
    http://projectzerog.com/sohc-dohc.shtml
    It is laid out in a straight forward manner and gets right down to what you need to know.
    Ronkonkoma
    1991 Mitsubishi Mighty Max
    I can't find anywhere where it says the pistons need to be changed when doing a dohc swap on 7bolt 8 valve 4g64 mighty max engine, but I'm 99% sure the valve relief pattern is for three and not 4 valves per cylinder. Can someone confirm the pistons don't need to be changed in a 1995 mighty max?
    WA
    I'm thinking you might experience contact. I would just change the Pistons, an out-of-round measurement on the cylinder walls would make me sleep better at night if it was my engine. An out of round might be the tie breaker in either direction.
