Results 1 to 3 of 3
Thread: Replacement Lights
    Lynchburg, VA
    Replacement Lights
    Anyone know where I can get some quality plastic replacement plastic lights? I ordered a taillight through Amazon and received it today. I thought the quality was poor. It had a foam gasket that was crushed crooked and the lens to housing margins are terrible. I need taillights, markers and parking lights.
    Pukwana, SD
    A guy is almost better getting original parts from a wrecking yard then that imported crap that the chrome peels off in a few months.
    Try car-part.com to locate the junkyard trucks in your area easier!
    Good luck. I got some which are probably the same as you can get from ebay. made in china
    One of my tail lights was original and the other a taiwan repo. I would suggest re using the original housings if possible. Mine came with no gaskets, and i had to repin the plug to get everything to work. The lenses were just ok, i had to replace mine because they had faded. THe new ones were about 1/3 the thickness of the original. They are not perfect in shape either so the body lines/gaps are a little out.
    Used original is the way to go, or if you can find NOS grab em
