Results 1 to 2 of 2
Thread: Engine Swap
    Killeen, Texas
    Engine Swap
    Hello everyone. I am new to the site. I just bought a 1994 Mitsubishi Mighty Max standard cab, 4 cylinder, 5 speed. I was really wanting a extended cab. I actually found one. It is a 1988 with automatic but just has the block of the engine. I was going to pull the engine out of the 1994 and install it in the 1988. I happened to find this site and figured I would give it a try. Anyways was wondering why I need to do to make this work?
    Online
    Pukwana, SD
    What's the swap? What trans are we talking here auto or stick the center humps are different between the autos and manual transmissions. It might be easier to put a 4X4 manual trans cab over a auto cab as they seem to have more space to access the transmission on the manual.
    Modifications can be made in a pinch like lifting the cab a inch in some cases. If they are both G54B engines no problems there, what is the other engine?
    When I need to see what will fit what I look at car-part.com and try to figure all the parts involved and see what differences exist.
