Results 1 to 4 of 4
Thread: Wheel Fitment
    SPOKANE, WA
    Wheel Fitment
    Hey all. So i found a pretty good deal on some 15"x10.5" wheels and 31" tires mounted with about 60% tread left for $400. Just wondering if i will need to modify anything to make 10.5 fit. I know i will need to lift the truck a bit to get the 31's to clear.
    Any info on this would be much appreciated!
    Owensboro, KY
    4D56-T
    31x10.5 tires will rub bad up front,they should clear OK in the rear, but to make them fit in the front you will need a lift of some sort. You can always turn up the torsion bars but that will make for a stiffer ride.
    you also need to trim the inner wheel well to allow for clearance
    mine are not quite that big, but they rub on the steering box and sway bar, livable by turning out the steering stops and losing turning circle, but its like driving a lowered car and rubs when going in driveways on an angle
