Results 1 to 7 of 7
Thread: rough running 1990 d50
    Acme, wa.
    1990 Dodge Ram 50
    first timer here
    1990 ram50 2.4l auto.
    runs rough
    pull #2 plug wire engine dies
    pull #1,3,4 engine does not die, no change
    new plugs wires cap rotor coil fuel pressure reg.
    fuel filter good compression, leak down test is good.
    all help is appreciated
    Get the fault codes from the ECU and see what errors are coming up. When did the problem start, had you changed anything before issues cropped up? Bunch of things can cause malfunctions (bad fuel pump, faulty relays, faulty ECU, bad ground leads...).
    ...and by the way - welcome to the forum, Woolley!
    Acme, wa.
    1990 Dodge Ram 50
    thanks for your reply
    I have replaced dist, cap,rotor, plugs, wires, fuel pump relay.
    ecu says normal, but this truck sat for awhile, w/no battery, once the batter y is disconnected ecu looses codes, correct??
    I have fuel, but intermittent and weak spark.
    thanks all
    Your coil pack may need to be replaced. They break down after 10-15 years. One of the main culprits for poor running and fuel economy. Maybe try some fuel system cleaner in the tank. Injectors can get gummed up. Also go over all the ground lead connections and give them a good clean up. Dirty grounds wreak havoc with the electrical system.
    Quote Originally Posted by Woolley View Post
    thanks all
    This is true but if it has a code issue running the motor and driving it will usually reset any unfixed codes that were deleted by disconnecting the battery.
    FRESNO CALIFORNIA
    1991 Mitsubishi Mighty Max
    it's a pain but have you tested or tried moving fuel injectors around?
