Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Thread: Let's Talk G54B Mods
  1. #26
    Couple of things about the 3.0 rockers: first, you must have hydraulic lifters to use them. Second, they are a 1.6 ratio to the original 1.5 ratio, so you get better performance from the same cam due to higher lift. Third, I would install new valve springs with the rockers and new lifter - old springs could break from increased compression of the springs, and new lifters so they don't collapse with the new rockers. They also are roller tip on the cam side for less friction - this is a common mod for the starquest groups.
  2. #27
    Whenever I see performance mods write-ups for the 2.6, duration is the key to improved power. It's generally accepted that lift doesn't help (and depending on who is writing what, extra lift allegedly kills performance) Hydraulic heads are not ideal for performance and are incapable of operating high lift cams or HD valve springs as they rely on oil pressure to operate. Once the load against them exceeds the effort the oil pressure can exert, they no longer are able to generate full lift. Mechanical head, good porting and a wider duration cam and you're on your way to making ponies.
  3. #28
    Concord NC
    1981 Plymouth Arrow Truck
    Can anyone chime in on a recommended cam grind for my 2.6 build?
    Doug Thorley Tri-Y Headers, 38 Outlaw and full exhaust planned. Below is what schneider recommended and what I will go with unless anyone else has input based on experience.
    From Schneiders: "You want a little grind like our 250-60F"
    Yet the grinds listed on their site start at 260-270F
  4. #29
    Concord NC
    Sorry...
    They recommend 250-260F but the grinds listed on their site start at 260-270F
  5. #30
    We have headers for sale in the for sale section sticky. DG Headers makes them for us. He has the full Doug Thorley try Y and a shorty unit.
    As for cams you only have 1 out there you can get and it's a regrind. So it's best to talk to your local machine shop.
  6. #31
    Concord NC
    I already have the Doug Thorley Tri-Y and I know cams are all regrinds. The engine is rebuilt but plan to swap the cam out with one from schneiders.
