Freshman
Drop spindles
So I got my drop spindles ordered for the truck. But I was wondering if anybody has flipped the lower ball joint while running drop spindles?
If so how much drop did you get with that combo?
I also have the bags and brackets for the front as well.
For now I'm running 16" Z71 wheels with a 205/45 16 eventually I'm going with 18's.
I plan on re doing the trans crossmember so it doesn't hang below the frame and moving the gas tank.
The back will be a 3 link with bag on axle.than
Will I need to do much more to lay frame on the 16" wheels?
Thanks
