divers door switch 91'
1991 mighty max over head light door switch. anyone know where it is, and what type. door plunger type? or in the door itself ? any help, comments help is depreciated. thanks Gs.
Plunger type I believe under a black rubber cover. Bottom rear corner of door frame. Phillips screw holding mine in place.
Senior
If i remember correctly you can access it in the b pillar at the bottom behind the seat i think there was a connector but im not sure how to reattach it. If you find out a replacement can you update the thread ive been needing to do mine but havent yanked it out yet
