Quote Originally Posted by ragragtimetime View Post
you mentioned leaking....if oil got on the clutch disc it should be replaced...are there signs of slippage? or was there throw bearing noise (prior to removal, running with clutch depressed)....if so i'd replace the clutch, disc, throw & pilot bearing & resurface flywheel.
As far as I know, I didn't encounter such problems. Although, when I would shift into reverse I could hear gears grinding, no matter how I adjusted my feet to the clutch. The clutch cable may need adjusting?: http://www.mightyram50.net/vbulletin...hlight=reverse Also I don't know if all this gunk inside the transmission is because of a leak?:
I am trying to remove the part(big red circle) circled in red, but it just wont come off. Do I have to thread a bolt to remove the part like how you remove the steering wheel? (small red circle)
