Results 1 to 6 of 6
Thread: Sun visors that DON'T fit
    Tampa, FL
    G64B
    I'm sure there are plenty of people out there they are sick of seeing the sagging drooping sun visors attached to the ceiling. I checked a bunch of cars at the junk yard yesterday in an attempt to find a direct replacement, but no luck. So, here's a list of all of the Mitsubishis that I checked (it was too hot to start going through other makes).
    2000+ Galant
    All Montero Sports
    2G, 3G and 4G Eclipse
    All Outlanders
    1996 Mirage (this does have the same rearview mirror)
    2000+ Diamante
    The problem with the above is the distance from mount (all mounts are different also, but the truck mount should be attachable) to the area that clips in which is greater on the truck than any of the above. I don't really want to refinish my sun visors, so if anyone has anything to add, please do.
    Pukwana, SD
    What color you looking for?
    Tampa, FL
    G64B
    I'm looking for gray.
    Pukwana, SD
    Have a set in the shed had stuff sitting on them but they need a cleaning no rips or tears off a 87 or 88 would they work?
    Tampa, FL
    G64B
    Those would work.
    Pukwana, SD
    $30 shipped priority mail they are just sitting on the shelf here I parted out a couple of trucks and have my shed full of parts I hate to waste good parts!
