Is 1991 Mighty Max 2wd engine 100% identical to 1993's engine
I got a 1991 MM 2WD donor vehicle for my 1993 MM. Looks like the air filter and MAF sensor are quite difference. Just wondering is the engine and tranny are 100% identical and interchangeable.
If you install the intake manifold and distributor from your 93 engine onto the 91 engine you will not have any difficulty with different electrical bits.
If you want to go deep on this topic you may find this site interesting
http://projectzerog.com/index.shtml
