Results 1 to 5 of 5
Thread: Weber carb question
    Atlanta, GA
    4G63
    Thanks guys,
    It has a 2-4 psi pump and a regulator. It will only hold 3.5 psi and falls to 2 psi after few minutes. The previous owner said the truck wasn't save at hey speed because it would starve for fuel. He put a small filter inplace of the factory unit. I bet that is part of the problem.
    Quote Originally Posted by 86goldmightymax View Post
    Thanks guys,
    There is your issue. The fuel pump is being strangled by the undersize filter. Try a filter with bigger diameter inlet/outlets + hoses before upgrading the fuel pump.
