need parts for my 1984 MMax diesel
need parts for my 1984 MMax diesel - fan shroud - flywheel cover plate (bottom) - one intake rocker
Moderator - please move this to parts wanted section.
Senior
Fan shrouds don't exist to my knowledge. Not for the diesel engines at least. You'll have to build one. It would probably also be easier to just build that cover for the flywheel at the base of the transmission as well. A piece of sheet metal that you cut and bend and drill to your needs. Finding one will take longer than it will to just build one.
I have a set of used rockers. I'd rather part with the set versus just a single rocker. PM me if you are interested.
Fan shroud off of a montero works.
Freshman
Mine has a fan shroud but I don't know if it was installed by a previous owner.
