93 Mighty Max lowering options
Recently I have been thinking of lowering my stock 1993 mighty max... I am wondering how you guys do it and what are the pros can cons of each options... So there will be a lot of questions. I will highly appreciate your input..
1. How much to drop?
I am wondering what is the realistic amount of drop for the front and rear respectively..
I just measure my stock truck, front tire is 3-3/4" away to the fender, and rear is 6-1/4" to the fender...(Why rear is so much higher than front? My truck should be stock)
Should I go with 3"? Or should I go with 4"? Will 4" be too much? Will the tire rubbing fender when truck run over bumps or is loaded with heavy stuff in the bed (like a motorcycle)
For the front, I guess 2 - 2.5 in drop will be enough?
2. How to drop in the front?
Should I use lowering springs or drop spindles? Lowering springs are about 100 cheaper than drop spindles...
I don't like cutting springs...
Anyway to find cheap spring with the right force and height?
Will dropping 2.5 in causing big enough camber change and thus causing premature tire wear?
What is the handling difference between two trucks, one has lowering spring, the other has drop spindle?
3. Steel drop block or aluminum?
I feel like the steel ones will be stronger than aluminum ones... Maybe aluminum is strong enough already?
4. Handling after drop
Will dropping the truck benefit the handling? I would imagine a lower center of mass will definitely help.
Thank you in advance~
