1988 dodge ram50 sport 2.6l with a Weber 32/36 DGEV Electric Choke with a manual gas pump
@ around 60-65 mph i get blow back threw the carb almost like a back fire this just started happening .
so the other day i was going into town have a little hill i have to climb about half way up i,m running around 60-65 mph the rpm start to drop and suddenly pop, spit, sputter cuts out .
i reach up turn off the over drive the rpm pick up but i,m still getting the what i,m calling blow back threw the carb it's like it cuts out
then when i let off the gas it's ok.
it does it under a load like pulling a hill with my 14 ft flat bottom aluminum boat.
it will also do it without the boat just not as bad.
so is this a carb going bad?
we check (my mechanic ) the timing right on the money check the vacuum plenty of vacuum no leaks getting plenty of fire
when you take the breather off there is black in the carb from when it pops back aka *back fire* so before i go investing in another carb*$299 ebay. what can it be?
thanks for any help on this one guys
. I'd mark the distributor now at it's current tune point so you have a reference to work from. A bit more tweaking and carb adjustment, and it should pull nice and strong. The Weber is more responsive to ignition adjustments and can handle a more aggressive tune due to a greater CFM + air/fuel mixture.
