Sophomore
Intake Problems
So with no luck I've been trying to fix the vacuum leaks on my intake. The Mikuni Phh intake sucks to work on because there is no way to take it on and off with out disassembling everything. I'm running out of patience for these carbs and am starting to wonder if its worth the hassle. Would I be better off to cut my losses and put the factory intake back in? I still have the manifold and the replacement weber looks far simpler than dealing with the dual carbs. Would I be able to return to the factory intake without the factory cam?
