Results 1 to 2 of 2
Thread: Wheel spacers.
    mass.
    1991 Mitsubishi Mighty Max
    Wheel spacers.
    Will adding wheel spacers eliminate problems with wheels fitting the hubs. Also any any problems with wheel rub after installed?
    Yes you will solve the issue of the hub bore being too small but then you are going to have issues with the wheels rubbing fenders if you are low enough.
    Josh
    09 BMW 335i E92 Twin turbo
