I am new to this site, and have already found it very helpful. So, thanks everyone!
Now, I'm working on an overhaul of the carburetor on my 1989 Dodge Ram 50 2.0L. All was going fine. Took it apart, removed the float and then went to remove the feedback solenoid valve (FBSV). I rushed the job and the wires broke off the solenoid right at the base. Here are some questions
Does anyone know where I might find a replacement feedback solenoid valve? Is there another name for it that I should be searching? I swear the internet doesn't even know what this is.
The end of the wires look pretty good. Could I maybe solder them back to the solenoid? There doesn't really appear to be a metal connection, just a little plastic harness.
Also I want to replace all my little vacuum hoses. I ordered a roll of hose online and they seem a bit more slender than the old ones, though they fit on the nipples fine. Is this an area to be real particular in?
You may have guessed I have very limited mechanical experience and this is the only vehicle I've ever worked on, though so far I've done all the work myself. I use the Chilton's, and family and friends a lot for advice.
Thanks for any additional carburetor rebuild tips and tricks you want to share.
