Results 1 to 4 of 4
Thread: Steering wheel
    mass.
    1991 Mitsubishi Mighty Max
    Steering wheel
    Any good options with steering wheels thanks. Gs
    90-94? Mitsu Eclipse/Eagle Talon/Plymouth Laser wheel bolts right up, only mod necessary is to open up the steering wheel opening on the upper and lower steering column covers. Should be a pic of it installed in my build thread somewhere.
    1993 Mitsubishi Mighty Max
    I'm running a MOMO on an ebay sourced hub.
    Grant has an adaptor that will let you run all of their wheels - be sure to get an extension housing to move the wheel closer to you and away from the turn signal / wiper levers
