Results 1 to 16 of 16
Thread: 4d55 Might Max, Repair Questions, Usual Newbie Stuff
    Inwood WV
    1991 Mitsubishi L200
    4D56-T
    So, broken rocker arms tend to be from broken timing belt or belt installed incorrectly. It is possible he over tightened the valves and they slapped the pistons breaking the rockers.
    Passenger side oil can be leaking from Valve cover/turbo oil feed/turbo oil drain/oil filter/oil sensor/front seal/oil pump
    on a d56 the vacuum pump is on the back of the alternator, which drains to the pain, that can leak as well. Most of these will not stop leaking with the stop leak.
    Tell him STOP DRIVING IT, these cranks are very hard to source, that crank is probably already ruined now though
    injection pumps should be the same, if you swap a pump you will need the dial indicator tool to set the timing
    the injectors are probably going to be different between the years
    Cracks on the head are common from poor maintenance, they can/will cause overheating as they will crack into the coolant chamber sooner or later, and start burning coolant
    Turbos are only rated 50k miles on these engines, same rating as the timing belt. you will either have a no wastegate TC05-10a, or a wastegated TD04-9b (not the same as a 3000gt)
    Replacement, the only GOOD place i have found is kinugawa turbos.
    If you block the oil feed, and oil drain, you can remove the turbo and make a custom downpipe off the manifold. It will be gutless, but the non turbo version isnt much different
    (likely will not be able to hit more than 45-50mph)
    Sonoma County, California
    1983 Mitsubishi Mighty Max
    4D55-T
    Quote Originally Posted by skullzaflare View Post
    That makes more sense than overtightened. The fuel tank needs replaced because there's a huge dent on the front, looks like they drove over a stump. I think they just thrashed the thing with little maintenance.
    Vacuum pump is oil driven? Or cooled? Didn't check that, thanks. Would an oil cooler line bursting cause a sudden loss of oil?
    No worries, he ain't driving it. He parked it as soon as the oil light went on and got some oil, then he limped it home really slow and it's been parked since. But yeah the crank may be shot. His hope is to get the '85 running and then work on the '83 when he has time and rebuild the motor. donor motor might be a better option.
    So we are taking the head from the '83 and putting it on the '85 block. If we use the '83 injector pump as well then there shouldn't be any matching problems, right? And as far as the dial indicator, lining up the match marks aren't good enough in this application?
    To clarify, the '83 head is crack free. The brassy looking nozzle things where the injectors and the glow plugs go are what have cracks. Are these replaceable?
    Excellent, that's what I needed to know. This is going to be VERY temporary. My friend wants to daily this thing so guts are a must. Does the injection pump need to be adjusted for lack of turbo?
    Thanks for your insight!
    Inwood WV
    4D56-T
    Quote Originally Posted by cabbagehats View Post
    The vacuum pump on the d56 is oil lubed, I do not know how/where the pump is on the d55. I know the ranger d55 had a normal ford pump up top.
    If an oil cooler line broke, you would drain the pain in less than 30 seconds ( i have done it before lol)
    The injection pump isnt bolted to the head. If you remove the pump, you have to put the pump back in time. The timing markers of course you need to follow for the pulleys to be lined up, but the pump has timing, similar to a distributor, except more dangerous and no light lol.
    I would suggest not touching the pumps, swap the head, adjust valves, use as is
    the cracked pieces i would need a picture of, i cant picture the parts you are talking about, unless you mean the injectors themselves or the return plumbing
    4D55-T
    ​Might have been the oil cooler line then, I didn't get a real good explanation of what happened. Just he was driving it, the light went on, he went and got oil and limped it home. could be the stop leak fixed the line. But not likely.
    Thanks for the heads up on the pump, We didn't get to it yet so we'll take your advice and try leaving as is first. Nice thing about this progressing so slow is there's plenty of time to dodge mistakes.
    here's the pictures (I hope):
    first two show the worst of the cracks, first picture is #1 and the second is #4. Last one is #1 again and you and your viewers might care to notice I got the intake and exhaust valves all switched up.
    College Station, TX
    1984 Dodge Ram 50
    4D55-T
    Turbos are only good for 50,000 miles? Then what? Are you just supposed to rebuild them ever 50k? I wasn't aware of that figure.
    Inwood WV
    4D56-T
    Quote Originally Posted by Uncle Spence View Post
    Thats what the manual stated lol. Said it should be rebuilt around 50k lol. Guess depends how hard you are on it lol
