Thank you for the manual pictures. Pulled the timing cover off last night. I'm still in shock. Crank was one tooth off of the cam and injection pump. The cam and pump were in time with each other, but we're one tooth behind the crank. Very surprised that it did not make valve contact the best I can tell. Tonight I am going to redo the timing belt procedure, and see what happens. Thanks for all the help.
Senior
One way to tell if you hit the valves, you will break the rocker arms
