Results 1 to 13 of 13
Thread: 92 ram50 issues
    golden,CO.
    1992 Dodge Ram 50
    92 ram50 issues
    I have a 92 ram50 with 2.4l. Its been running good til the other morning wouldnt hardly start and the check engine light came on. codes 13,15,21,25 came up. Why would all the code come at once? ECM went bad? Still runs smooth just really hard starting when cold. It use to have high idle when started but now it dont. ohmed the sensors and couldnt find a bad one. Any Ideas
    Thanks
    possible bad MAF, moisture in connectors, or caps bad in ECM. What are the codes for?
    golden,CO.
    1992 Dodge Ram 50
    intake air temp sensor, idle speed control motor position sensor, engine coolant temp sensor, barometric press sensor.
    golden,CO.
    1992 Dodge Ram 50
    before I could unhook battery and erase codes now cant
    kings mountain, nc
    Chevy V8
    Its possible there could be a bad ground that they share but would have to check a wiring diagram to see
    golden,CO.
    1992 Dodge Ram 50
    I will look it up and see
    Change the coolant temp sensor first. One guy had the craziest problems with his truck running funny/rough and he changed MAF and ECU and TPS and it ended up being the temp sensor. That one tells the ECU what temp the engine is at and the ecu calculates how much fuel to give, I guess when they go bad they tell the engine to go super rich and causes issues. If not then I'd try the MAF next since it is throwing 2 codes related to it.
    Josh
    09 BMW 335i E92 Twin turbo
    Kansas City, MO
    I'd make sure the grounds for all those things are good, and also that they're each getting the 12V they need. Should be easy enough to test with a multimeter.
    golden,CO.
    1992 Dodge Ram 50
    Yep, the first thing I changed was the coolant sensor since it is the cheapest. No change. I think I will start checking all sensors at the computer before I spend 100 on a map sensor. I pulled the Idle speed control motor and sensor since it was one of the codes and the motor moved like it is suppose to but the ohm didnt change on the sensor like the book said and when I looked up the part it said not avail. Not sure if that affects it or not , but I bet its the map, air temp, baram air flow box.
    Thanks
    golden,CO.
    1992 Dodge Ram 50
    UPDATE!!! I took the ECM or computer in to a local guy and he said he has done 1000 of them, not so many now since there isnt many ram 50s out there. Natorious for goin bad. Cost 175 but everything works great and no check engine light.
    Bothwell,Ontario
    Dodge V8
    was it the caps that went bad?
    Kansas City MO
    so, what did he do? replace the whole ecm or rebuild the existing one?
    Quote Originally Posted by KCKC Amy View Post
    They replace the bad caps in them and if the caps have eaten tracks off the board, they run bridges on them to complete the circuits. If you are game and can get the values off the capacitors, you can DIY this job (also eyeball the board for dry soldered joints and touch them up...)
