Results 1 to 25 of 118
Thread: My 4d55 performance build
    Portland, OR
    1989 Dodge Power Ram 50
    i'm not sure that i understand the running gear thing you were talking about. is that because of the short powerband that diesels have?
    Benton, Ks
    1984 Dodge D-50
    Diesels don't have a short power band. Actually given the rpm range, their power band is much longer than a gas motor. Its because the gearing is taller than normal, the tires are much bigger than normal, and its a relatively heavier vehicle. Its coping better with the extra power, but 75mph in 4th without the engine screaming is a bit too high geared.
