Results 1 to 25 of 28
Thread: Tube Front Coming Together!
    Copperas Cove, TX
    that fuel cell setup is impressive, very minimalistic, and the jumper point is a very nice touch! never seen that before! stay innovative my friend!
    Raleigh, NC
    1991 Mitsubishi Mighty Max
    Quote Originally Posted by Pilot Abilleen View Post
    thanks a lot! Yeah I had my eye on this cell for a while. It's a little pricey, but since everything is contained inside, you just hook up the feed and return/power and ground/level indicator and you're good to go. It's got an eliminator pump in it which supports almost 900 on ethanol, and over 1400 on non-alcohol fuels. The inside is baffled so by running this, there's no need for a surge tank and multiple pumps. Cost ends up about the same after you plumb everything. I appreciate the kind words!
