The 'floating' bit is the part of the caliper that does all the work (the piston housing). It works similar to the fixed caliper but instead of the centre of the caliper moving on metal shims, they are on greased slide pins on top and bottom of the caliper mount sealed in with dust boots. And the first thing I did mention in my previous post that the swap requires the entire hub assembly from a Gen 2 -
"...So I took the plunge and bought a pair of Gen 2 steering hubs and rotors for my Gen 1 brake upgrade."
Mitsubishi was wise enough not to change the bolt pattern even though the brake design had changed. Simply a matter of removing the 2 x 17mm bolts holding the caliper mount on from the rear of the steering hub and the 10mm bolt holding the backing plate onto the end of the caliper mount, and the whole caliper can be pulled away from the hub. Not that you'll need to pull the Gen 1 calipers off if you are intending the brake swap, but it will make it lighter when you knock the steering hub off from the ball joints to remove it.
That doesn't even factor in new brake hoses, shocks and tie rods...and then I can start work on the rear end. This poor biatch still had all the original factory assemblies in it. Getting the used Gen 2 hub assemblies has so far been the cheapest part of the front end - and that set me back $188 with the twin piston calipers. Let's get back to da thread now!
