Results 1 to 9 of 9
Thread: 95 4g64 timing issue?
    Greensboro NC
    Ok guys so decided it was time for me to replace the timing and balance shaft belt along with some other things since I'd never done since I bought it a year or so ago.
    I installed new valve seals (smoking very bad) lifters (ticking pretty loud)
    timing belt
    Balance shaft belt
    Water pump
    Plugs
    Wires
    Fuller filter
    Oil change while I was at it
    And flushed the coolant system
    Went to start it up didn't run ( I had the distributor a tooth off, fixed that)
    Fired her up ran fine no smoke no tick let it idle and bled the coolant system and let it run for another 30 mins then drove it to the store a mile or so from the house and filled her up with gas. Came out started her right up drove her home.
    Now for the weird shit....drove her to the parts store (8.5 miles from home) for a thermostat and gasket for my other daily I picked up and was driving since I was in the process of doing everything to my truck for the past few days. Came out and it wouldn't start sounded like a bad starter. Towed it home till I got paid bought a new starter got home installed it and same thing, put a new battery in it (had 12.7 volts just thought the cold crank amperage may be low) Fired right up but now the starter is dragging, drove it again for 4 miles the check engine light came on and running on 2 cylinders ( pulled the plugs running rich on #1 and 2 cylinder and lean in the rear 2) put in new plugs and the same thing.
    I pulled the timing cover and all the timing marks are lining up besides the oil pump ...so what to do from here? I'm very mechanically inclined and I'm stumped this should have been a simple deal now I'm several hundred dollars in parts and my daily that love doesn't run.
    Any ideas....?
    caps in the ecm - they leak and then the truck either quits running or runs badly. There are threads on here that tell you what the values are and how to replace them, or where to send it to have it repaired.
    Greensboro NC
    Thanks man guess I'm pulling and inspecting tomorrow
    Georgia
    1984 Dodge D-50
    4G63
    Quote Originally Posted by Nicbishop89 View Post
    Can you post the results......I'm in sorta the same boat.....?????
    Greensboro NC
    Yeah have to go get my new daily inspected today after work then headed home to check it out
    Greensboro NC
    So the computer isn't bad, didn't smell burnt up looked brand new and everything checked out
    Durham, NC
    Following.... I've been having a hard start/ not wanting to keep running problem when cold for about a month now. Just haven't had the time to actually diagnose what's wrong with it yet due to work. And its done the "starter bad" click for years. It always starts after I turned the key on and off a few times.
    Maybe go through the wiring loom and ensure all your ground leads are clean and have a good, solid connection to the engine block and chassis. Bad grounds cause all kinds of problems.
    Greensboro NC
    Didn't smell burnt up didn't see any burn marks , all capacitors visually looked fine not swollen on tops or as if anything has leaked, I've already check all grounds (first thing I did as I think it's an electrical issue) but one thing I forgot to mention when I was setting the distributor I could hear relays turning on and off didn't think anything of it since it ran perfect before this shit started....
