They do not have the same size shaft. I had to bore out the center hole on the 2 discs (the pulley is 2 pieces). And then find a different bushings to go behind the pulley. And it seems to be fine. On a tight budget, so I had to use what I had. Just updating, If anyone else is looking to go with the Montero alternator on the 4g64.
