Sophomore
Unfortunately it can't. It split the case in half. So what was once 1 is now 2. I guess ill have to fork over some money on a new one. I guess it could be a good thing since I am doing a rebuild here, but I don't see something like this and the water going bad very often seeing as the way they are designed. I could see the seals starting to leak but those where going to be replaced anyways. I was just hoping someone might be able to come through with a used one for much cheaper. Thanks for the advice though. In other new I might have found a donor truck for a front clip if I can get the guy to part with it. He constantly has complaints of it not starting. His body is in rough shape though, but those parts are not what I'm interested in. Ill get some pictures posted soon along with one very important picture of an ooooopppps the machine shop made that either will either cause grief or not.
