PLEASE HELP 1982 l200 nz
hi guys im currently in the process of completely stripping my l200 for a nearly ground up rebuild and ive decided to get rid of my cut springs and lower it properly as I will need to to get a certification for the modifications. if anyone has lowered their d50 or mighty max or whatever can you please post a photo and note what u did mine is currently cut in front and is pretty low but I don't mind bringing it up a bit to gain more travel. I was looking at importing the belltech 2.5' drop springs but im not sure ill be happy with the height and I don't know if I want to run drop spindles as I think the could possibly rub as im running 16x8s cheers in advance
all advice/opinions apprected
