If its spinning nice on the bench, but not so well on the truck i would look for a bad engine earth strap (if one is even fitted, i once had an engine earthing through the choke cable). I have previously added a ground from one of the starter mounting bolts to the frame and it really increases the power going through the starter
I think it may have to do with me removing that ignition bypass wire to the ballast. To me it sounds like it is not getting spark/igniting the fuel. I can smell the fuel and it is turning over well. Last time I drove the truck, it did sound and feel like it may have a miss. Probably replace wires and plugs too, but first I am going to see if it is getting spark.
