We have a link to sites that can give you specific fitments for your tires and wheels. Cars and trucks have the stock size wheels and there is also the oversized wheel specifications that are available. This usually gives you the biggest set you can install without carving them up. Also roll the fender a bit to secure a safe fit if you like. This will make sure even if they possible tap the edge occasionally, it will not shred them.
