Results 1 to 25 of 25
Thread: Rear end options and upper control arms
    Rva
    I have a 95 MM I'm trying to figure out if
    -the 1st gen montero sport rear is a bolt in affair ?
    -what size wheel would I have to run to use that rear
    -what's the track difference on the Montey vs the MM?
    - how hard is it to put a locker in an open diff?
    For the upper control arm
    - can I use the Monty uppers or is there an after market upper that takes the bolt in style ball joints ?
    I have been searching but there seems to be a lot of conflicting or lack of info on what I do find, any help would be great
    1st gen rear is a bolt in, but the gear ratios may be 4.22 instead of 3.91 - you would have to change out both front and rear diffs then. Not sure if the 95 MMM has an 8" or 9" rear - if 9" rear a 2nd gen monty has the right size, but is a coil spring and arms setup - you can swap the center section and disc brakes onto the truck axle. the monty axle is 1" wider than the truck diff. 15" and up for the 1st gen, 16 for 2nd gen with disc brakes. you need the 2nd gen monty upper arms for the 95 truck - 1st gen arms are the same as the truck arms.
    Nevada
    As long as the monty is leaf spring you can swap over. Pretty sure the I4 MM had 8" rear axle. The V6 MM have 9" rear. Swapping over disc's is not an easy affair either. You would have to do some welding and pressing of bearings etc. Your best bet is to find one out of a 97-99 Sport that is leaf sprung (hard to come by). Depending on if its a 3.0 or 3.5L you can grab a 9" rear or the 9.5". I got lucky last month and came across the 9" that is a direct bolt on for my v6 MM. Sometimes they come with LSD in them or with air lockers. Mine didn't but I already have a LSD that I will toss into the 3rd member.
    Rva
    Ok on the uppers my truck is 2wd 4g64 is that an issue, I can get the Monty sport rear I work at a truck salvage yard and there are two in the yard now sadly no LSD but both leaf, idk about the disk now I don't really want to be forced to 16's just for rear disk ha
    I thought you had a 4wd - the Montero uppers won't work. You can buy replacement stock arms, but they are press in ball joints
    Nevada
    Who says you need 16s?
    Rva
    16's to clear the montero rear disks
    Nevada
    Not needed. My 95sr has 15's from the factory and discs all around.
    Rva
    I'm probably going to have a sport rear from a 98 with rear leafs I was checking them out the other day and it looked pretty close with the 16 on the rear idk tho
    Nevada
    Do I need to mount one to prove they fit?
    Rva
    seeing is believing for me lol, not that I don't trust Its just hard to find info for most of this stuff, I been looking and its like one person says this is the stipulation and others say it will work straight up, I just don't want to spend on something that im not using right away or that will hold up my plans, I can get the rear for like 30ish but none are lsd
    Rva
    so are 15's the lowest size I can run right?
    Nevada
    Quote Originally Posted by Hypeonline View Post
    Im not home at the moment, but here you go. I have these exact wheels on my Max. They are 15". I pulled them off my 95 SR Monti with rear discs. Plenty of clearance.
    Why would you want to run any smaller? You get crap choices for tires.
    Rva
    Not to rub smaller my truck has 14's as is I could get the Monty wheels but id definitely need tires
    Rva
    I'm planning on running adapters for either 5×114 or 5x120
    Nevada
    My 90' 4x4 for reference.
    Sorry if I caused any confusion - I must have been thinking about 3rd gen monteros and 16" wheels.
    Rva
    OK cool looking like it's all going to come together
    Rva
    ok one more question will the coil spring rear gears fit in the leaf sprung rear, I can get a open diff rear but I want a locker, if I find a locker in a coil spring rear can I just swap out the guts to the open leaf spring rear?
    Nevada
    9" diffs interchange. 9.5's also interchange amongst themselves. Make sure you know the difference.
    Rva
    Ok I'm in the process of getting the rear and what I have found is I do need 16" to clear the rear it's a leaf sprung Monty sport, is my truck being a 4 cyl going to have issues with the yoke and flange bolting up I seen some people say they seen various differences on the flanges, oh and what all do I grab off the Monty do I need the master cyl / prop valve I need to make sure I have what I need to do this
    Nevada
    Your current stuff works. You can upgrade if you like as it would be a slight improvement. I wonder what 15s you are ruining because mine clear. Grab the e-brake lines too. Yoke won't work. Not sure what you need for your specific swap.
    We have a link to sites that can give you specific fitments for your tires and wheels. Cars and trucks have the stock size wheels and there is also the oversized wheel specifications that are available. This usually gives you the biggest set you can install without carving them up. Also roll the fender a bit to secure a safe fit if you like. This will make sure even if they possible tap the edge occasionally, it will not shred them.
    Rva
    It came out of a 98 Monty, idk, but I have found out the the brakes suck so hard in this truck almost scary haha, got to bleed the system def, cool I got all the hardware with time ie all brake parts, with lines, both e brake lines and a cut of the the drive shaft still attached, not I just have to wait for a locker ha
    Rva
    Oh I think I'll grab the parking brake leaver too might be doing a bucket seat setup and I hate that my brake light stays on
